Frame Generator End Treatment Errors
I-WANT-TO-KNOW
I-WANT-TO-KNOW
Hi all,
Is there an easier or quicker way to locate End Treatment Errors on parts that are "sick" after they have been modified using the Frame Generator Editor? Or, do you really have to click the (+) sign next to all the hundreds of parts in a Frame to see the End Treatments in hopes of locating the blue dot with what looks like an "i" in it??
blandb
It has been a while, but if you click on the Red cross at the top, and then highlight an instance in that dialog box, does that highlight in the model browser, or scroll the model browser, does that highlight the component?
Autodesk Certified Professional
I-WANT-TO-KNOW
@blandb, Thanks for replying; clicking the 'red cross' opens the Design Doctor dialog box which shows which items have errors. Then, you can Examine or Treat each part *one-by-one*, which is very time consuming when you have hundreds of items to fix. I'd rather the ability to find them all at once, select them all and 'Remove End Treatments'.
I-WANT-TO-KNOW
@blandb And that still does not fix all the errors. Had I not taken a chance on clicking these open, I would have not seen that they contained errors.
chris
Can you share an image of the actual parts and the constraint type?
