- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have a problem with the frame generator.
1- I create the sketch
2- I place this sketch on a assembly
3- I click on insert frame
4- I select the profile type and the lines in the sketch
5- After click "Apply" inventor doesn't work. I wait a lot of time but nothing happen. It's all the time as you can see in the next picture
I already check:
- Other profiles that I have. And I have the same problem
- Change the library. Same problem
- Create a new profiles and use it. Same problem
- Change the project. Same problem
- I've created a normal part using the content center with different profiles. I could create it without any problem.
Do anyone has any idea about why in my frame generator doesn't work?
Thanks!
