Frame generator dialog box missing options/wont work.
Bartlett-Pentagon
Bartlett-Pentagon
I can select lines in the skeleton, but there is no preview and the OK button is greyed out.
I can't get it to generate anything. I can open older assemblies and all the elements are there and work as expected. I've tried both 2024 and 2025 versions of Inventor, but same issue.
I cant see anything out of the ordinary within the project settings.
Thanks in advance,
Matt
CGBenner
@Bartlett-Pentagon
Hello.  From your image it almost looks like your Content Center library is not available, you should also see Standard, Family & Size in your dialog box.  Can you share an image of what you see under Category at the top, where it says All?  Also, check your Project t make sure all of the Content Libraries are available.
Chris Benner
Bartlett-Pentagon
Thanks Chris,
I just created a new project in the same folder and it's all working. Not sure what happened with the originals, but I'm just going to roll with it.
