Frame generator and pattern
Hello, I want to pattern only the I-profile 100 16 times without taking the U-profile with. How can I do that ? I have tried many things, but every time I want to pattern the I-profile, the U-profile is autamatic taking into the pattern feature.
SharkDesign
Double click the frame first before adding the pattern.
  Inventor Certified Professional
See video... I have nothing to sweap it around ?
SharkDesign
I don't understand the question. Your post said you were trying to pattern one without the other?
If you mean 'revolve' and not 'sweep' you can pick an axis from the origin in your browser and use the pattern.
Also you shouldn't be drilling down into the member itself unless you are trying to modify that section, you should pattern at frame level.
Hmm... do not work see new video.
SharkDesign
You're still doing it at assembly level.
Double click this one then do the pattern.
Ah thank you ! 😀
