Frame Gemerator: How to create different frames in the same assembly
Good Morning,
I use the frame generator to create complex design. The problem is that in the assembly all the components are gathered in the same frame.
It is possible to create different frames in the same assembly?
I attach an image that represents an example.
bhavik4244
@Anonymous
On the first site, you may make a single skeleton sketch and create new frames as per your need by placing the same skeleton in each new frame generator assembly, just need to assemble those with reference to the main skeleton so it will be intact.
Bhavik Suthar
So you suggest to create an assembly for each frame that I need and then put them in one "general" assembly?
I've already tought to this trick but, if it exists, i prefer  an in-built option of "frame generator" that allow to decide in which frame create the part
blandb
You can select the items you want Right click > Component > Demote frame generator components. This will make those items their own sub-assembly that is still tied to the original skeleton. But like other say, making your own different frame subs and placing them in the final assembly works well and keeps it simple too.
Hope that helps.
Autodesk Certified Professional
It will be a good compromise,
thanks to everyone!
Have a nice day
