Inventor Forum
Frame analysis
2 REPLIES 2
399 Views, 2 Replies
Frame analysis
Hello
I want to create a frame analysis for the attached files.
My problem is that it says "Unsupported frame members were found" I guess that's the rounded corners.
When I try to simulate it says "no constraint defined" but don't know what I should constraint.
Can anyone help with this
2 REPLIES 2
blandb
Pack and go your assembly, we are missing the frame.
Autodesk Certified Professional
Like this?
I made some changes to the rounded corners, but is it possible to use them somehow?
It also turned out I'm stupid about the constrains, I didn't realize I had to use supports for my construction.
The simulation should be in the pack and go zip?
I ran the simulation with 500 N on each of the top frames and the profile closest to he center turned red, which means that's where the construction has the highest load? But does Inventor tell me if it will break or do I have to calculate that myself based on the material I used?
Can I somehow see the maximum weight the frame can hold?
Technology Administrators
