Frame analysis report - Constraint Reaction sort order
pmaxwellNKJEX
pmaxwellNKJEX
Why does frame analysis seem to organise the constraint reactions in the report  in a random order?
It baffles me why it would do it this way.
Is there a way to fix this?
pmaxwellNKJEX
Can anyone shed a light on this?
I can't find rhyme or reason for it.
The requirement for post-processing to make it useable is nonsensical
johnsonshiue
Hi! Let me forward it to the project team to see if there is a good explanation. You may need to share the Inventor files.
Many thanks!
Software Test Engineer
jan_priban
Hello Paul,
I think there is no sort mechanism implemented, constrains in report are in the same order as constrains in Frame Analyses browser tree. As image shows. From my perspective it is easy to locate constrain in report by same order (or use CTRL+F to find required string in report like "Constraint:20")
Regards
Jan Priban
pmaxwellNKJEX
That's interesting that yours is like that.
Mine are in numerical order in the model, as I had planned it that way in the hope the results would be sorted.
pmaxwellNKJEX
Did the team come up with anything?
