Inventor Forum
Frame Analysis Menu (Inventor 2011) not displayed correctly
3 REPLIES 3
G.Barozzi
815 Views, 3 Replies
G.Barozzi
Frame Analysis menu options in Inventor 2011 (Italian version, XP64 and Windows7 64 bit) do not display correctly.
Some options are available by means of right-click, the rest is unavailable.
The appearance of the menu bar of the IFA environment is shown in the enclosed image.
Thank You
Regards
G. Barozzi
Thank You
Regards
G. Barozzi
3 REPLIES 3
Harrison_Luo
in reply to: G.Barozzi
Harrison_Luo
Hi G. Barozzi,
From your attached picture, I see you are not activating Frame Analysis (IFA) menu, instead  "Environment" menu is activated, so you cannot see frame analysis options here, would you please activate frame analysis menu then try again?
And I have a Italy R2011 Inventor on Italy XP64bit OS, everything seems good, please refer to my enclosed picture.
Harrison
Hi G. Barozzi,
Harrison
G.Barozzi
G.Barozzi
Thank you for the reply.
Please explain me how to activate the IFA menu: the IFA module is loaded at program startup but the IFA tab and its contents is not displayed when i press IFA from within the Environments section.
Thank you
Regards
G. Barozzi
Thank you
Regards
G. Barozzi
Harrison_Luo
Harrison_Luo
Hi G. Barozzi,
I understand your problem now, that is you cannnot get the frame analysis menu after entering frame analysis environment,  sorry to make you inconvenient. Would you please show me more information to help investigate this issue, like:
  1. The actions you did before enter IFA
  2. Can you still see this issue after reboot or unload then reload IFA add-in?
  3. I see from you enclosed picture, you have an "Additional  Modules" in your Inventor, so you should have installed another product, what's it?
Would you send mail to me directly? harrison-haiyong.luo@autodesk.com
Hi G. Barozzi,
