You can in this tutorial same sketch has decimal dimension and fraction dimension. Because in the drop down menu there is a fractional option.
In my drop down menu there is no fractional option. How to bring it?
Solved by TheCADWhisperer. Go to Solution.
Enter your dimension as 1/2" or 1/2in and you will have access to the Fractional in the drop-down.
(But actually it is not even needed any more (that video was from 2012) as when you enter as I indicated Inventor will automatically display as fractional in later releases.)
