fractional notation for driven dimensions
bgolash
bgolash
Hi
It looks like you can enter driving dimensions as 7/16. But it seems driven dimension
only display as .4375. Is this true or is there a option to change this condition to fractional.
I maybe wrong but Solidwork can display driving and driven dims as fractions.
Curtis_Waguespack
Hi bgolash,
Where do you want to display the dimension as a fraction? In the model sketch, in the 2d drawing? Other?
In looking at the driven dimension part of this, I'm assuming you've change the Default Parameter Input Display setting as described here:
http://help.autodesk.com/view/INVNTOR/2015/ENU/?guid=GUID-823253D9-FFC6-4708-9F37-207883ECA597
I'm now seeing what you're describing, where Display as expression displays as a decimal even if input as a fraction,but I don't know of a way change this behavior.
I hope this helps.
Curtis
bgolash
In the model space.ie sketch environment
mcgyvr
I always love it when people say "Well solidworks can..."
So what? Its a different program from a different company..
My Jeep leaves the radio on until I open the doors (or 45 seconds when I don't have the doors on at all) after shutting off the car.. My wifes Sorento doesn't do that..
bgolash
So what? Its a different program from a different company. Maybe that means that there was a demand for it.
Maybe Autodesk is too lazy to change the code.
mcgyvr
In case you didn't see that Curtis updated his post..
There doesn't seem to be a way to force driven dimensions to display in fractional like the normal dimension..
If you would like to add this functionality to Inventor then please submit your request to the ideastation for investigation.
http://forums.autodesk.com/t5/inventor-ideas/idb-p/v1232
