Inventor Forum
Forms and parameters to control parts
4 REPLIES 4
sijcooke
404 Views, 4 Replies
Hi All,
I am trying to control an assembly of 3 parts with parameters. What i was told was to create the assembly and add a standard part called 'main variables'. This part doesn't have any graphics/faces etc, it just has parameters such as 'boxDepth', 'boxHeight' etc...
Then i add some sheet metal parts to the assembly for the main box, and the lid etc... and in the parameters window these parts they link to the 'main variables' to get the values they need.
This works fine.. but the problem is that every time you open the assembly, you have to open the 'main variables' part to change the parameters (with a form) and then return to the main assembly to see the update. I want to have a form pop up from the main assembly asking you for the values you want, then on OK... everything just updates and additional rules on the main assembly will run...
Any tips would be appreciated.
Many thanks, sijcooke.
4 REPLIES 4
SašoPrijatelj
in reply to: sijcooke
Hi.
First of all place your part with parameters into main assembly (you can set its BOM status to reference so it won't be shown in parts lists) and then follow the solution shown in video below.
Side note: If you use iLogic then you can avoid having a dummy part with parameters because iLogic enables you to directly access parameters in parts. But the example in video is made for your original situation.
AutoDXF - automatic flat pattern creation and batch export to DXF for Inventor
Please use "Accept as Solution" & give "Kudos" if this response helped you.
Roelof.Feijen
Tip: Read page 8 and 9 from @PaulMunford AU presentation (handout).
http://aucache.autodesk.com/au2013/sessionsFiles/2604/1881/handout_2604_MA2604%20-%20Drive%20Autodes...
Roelof Feijen
If my post answers your question, please click the "Accept Solution" button. This helps everyone find answers more quickly!
sijcooke
in reply to: SašoPrijatelj
Thanks very much, thats a big help.
Best regards,
sjcooke
PaulMunford
in reply to: Roelof.Feijen
Thanks for the shout out Roelof 🙂
Autodesk Marketing Manager D&M
Opinions are my own and may not reflect those of my company.
Linkedin Twitter Instagram Facebook Pinterest
