Forming a Sheet metal pan with a Cross Break
Message 1 of 11
I am having trouble modeling a pan in my sheet metal.
The design should have a slight bend at 5* across the diagonals.
This creates a small depression in the center of the pan.
Replies (10)
Message 2 of 11
blair
Just two quick diagnanol hits to place "X" from corner to corner simular that is done with HVAC ducts to stiffen them. Sad to say, it can't be done yet in Sheet-Metal. You can place a "X" sketch.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
Message 3 of 11
Ok.
So I will just leave it as an open sketch?
Message 4 of 11
JDMather
What version of Inventor?
Can you attach your *.ipt file here?
Message 5 of 11
blair
I've left them "open" as a visible sketch but I am thinking back around release 2012 there was a function for leaving sketches on S-M items.
You might be able to use the Fold and Refold to get the "X".
Delta Tau Chi ΔΤΧ
Message 6 of 11
Here it is.
Nothing exciting yet.
I just need two 5* break across the corners
Message 7 of 11
I forgot to say that the it is 2016
Message 8 of 11
JDMather
Maybe this will be enough.
Must be in Flat Pattern.
Message 9 of 11
That will be perfect
Thanks for the help
Message 10 of 11
JDMather
Here is the part back - in case you have trouble figuring it out.
Message 11 of 11
blair
Thanks, I knew something was there for it. Don't do duct work and I remember beta testing it about 5-6 releases ago.
Delta Tau Chi ΔΤΧ
