Inventor Forum
format painter
15 REPLIES 15
Message 1 of 16
15862 Views, 15 Replies
format painter
another long shot,
i have just been wondering if anyone knows about a Format Painter tool / function like we also use in AutoCAD. this is the one that was accessible under commands such as:
" _matchprop ".
this would be good in inventor both part and idw environments.
15 REPLIES 15
Message 2 of 16
I think it's on the Inventor Wish List at http://augi.com
Dennis Jeffrey, Autodesk Inventor Certified Expert
Autodesk Manufacturing Implementation Certified Expert.
260-399-6615
Instructor/Author/Sr. App Engr.
AIP 11SP3, AIP 2008 SP1, PcCillin AV
HP zv5000 AMD64 ( modified)
Geforce Go 440, Driver: .8185, 2GB RAM
XP Pro SP2, Windows Classic Theme
http://teknigroup.com
wrote in message news:5711943@discussion.autodesk.com...
another long shot,
" _matchprop ".
Message 3 of 16
thanks very much dennis, i will follow up that augi.com area in future.
Message 4 of 16
There shouldn't be any need for a Format Painter if you're using Styles in IDWs
Once you've got your Style set-up all annotation will be the same. If you want
another Style in a drawing, just create another Style and change the annotations to
that new Style.
I can't see how a Format Painter will help in the Part environment. If you want to
change the colour of a lot of solid/SM faces there is a lovely little tool at
http://www.mcadforums.com/forums/viewtopic.php?t=3453
Duncan
"Humour ... is one man shouting gibberish in the face of authority, and proving by
fabricated insanity that nothing could be as mad as what passes for ordinary
living."
(Terence 'Spike' Milligan K.B.E., 1918-2002)
www.autodesk.co.uk/inventorjobs
http://support.microsoft.com/default.aspx/kb/555375
another long shot,
as:
" _matchprop ".
Message 5 of 16
JDMather
I'd go for that big time.
http://discussion.autodesk.com/thread.jspa?messageID=5016282
Been begging for one for a long time. The copy properties in idw has helped but I still need it in ipt. I saw a demo of SWX 2008 at SolidWorks World conference that "painted" the size of one fillet onto another. Very cool.
Message 6 of 16
It depends on what properties you're copying from one dependant feature to another
d/feature.
I thought you could already copy dimensions from one feature to a new feature you
are creating and keep them parametric/linked by using the Show Dimensions command
from the dimension field within the functions dialogue box, select the feature you
want to copy from and then select the dimension you want to copy.
Duncan
living."
wrote in message news:5712111@discussion.autodesk.com...
Message 7 of 16
JDMather
In SWX 2008 you can click directly on a fillet in the graphics window and match the properties onto another. No need to go get the dimensions. There are other powerful tools in dealing with fillets that put Inventor to shame (at least that was my impression from the demo - I haven't had the opportunity to actually play with it yet).
Message 8 of 16
There are two things I like about Acad. The ability to customise it in more ways
that you can 'shake a stick at'. I just wish Inv could be this customisable.
The second is the Properties dialogue, which is a very powerful selection, filtering
and property editing tool. If it could also allow you to filter and choose which
properties you want to copy it would be an ideal tool and one love to se in Inv.
I think a properties copying tool has to be able to do more than just copy
dimensions from fillet to fillet. You need to be able to copy/link and map
dimensions, face colour and suppression etc between different types of features.
This would be useful for iPart creation (compute/non-compute)
Duncan
living."
wrote in message news:5712438@discussion.autodesk.com...
yet).
Message 9 of 16
JDMather
Yes, I was just giving one example. It could be a very powerful tool.
Message 10 of 16
thanks people for your good input...hopefully our developers will sort it out for us soon.
anyway, i zapped it onto augi's wishlist, probably not the first time by the sound of it ;-\
-peace.
Message 11 of 16
I really don't understand why Autodesk doesn't just use AutoCAD or something like it as the 2D sketching portion of it's Inventor product. I used AutoCAD years ago before moving to SolidWorks for the past 7 years and have very recently started a new job that uses Inventor. I was hopeful that some of my old AutoCAD knowledge would be useful during the transition but it is basically like Autodesk reinvented the wheel and made it square. Even if they couldn't build Inventor off of AutoCAD why not at least make 2d sketching look and function the same way. I know I will be told this is not a place to rant & "Inventor is not AuotCAD" but my question is why couldn't it be? Thousands of people already know how to use AutoCAD so it would seem like Autodesk could really use that as an advantage when trying to convince businesses to select Inventor over their competition. And I am not ranting just posing a question.
Message 12 of 16
Curtis_Waguespack
@Anonymous wrote:
... just posing a question.
Hi @Anonymous,
Welcome to the forum.
You're posting to a 10 year old thread. Smiley Wink
I am extremely proficient with AutoCAD and Inventor, but I simply use Inventor and AutoCAD differently. They are different programs created and maintained differently, they just happen to be owned by the same company.
Often when we switch between applications its our own bias that holds us back. That was the case when I went from AutoCAD to Solidworks, and then later to Inventor. And these days I still suffer the same thing when going from Inventor to Fusion, etc. We just have to recognize this, adapt and overcome it.
Anyway, it's far too late for Inventor to  "just use AutoCAD or something like it as the 2D sketching portion". Inventor while possibly new to you, is a rather mature application at this point, with many many users that know it inside and out, so making changes to the foundation of it is not practical.
Plus many of us like Inventor's sketcher. Smiley Wink
I hope this helps.
Curtis
Message 13 of 16
Mark.Lancaster
@Anonymous
First it would help if you didn't reply to a 10 year old posting and that most of the users who did participated in this old posting have archived accounts.   Smiley Wink
Secondly..   You have your opinion and that's fine to share and voice.  Yes we may see your posting as ranting but right now that's what it comes across as.
In the end I'm not going to tell you that Inventor is not AutoCAD and AutoCAD is not Inventor (ok i just did Smiley Very Happy) but I have to ask why do you think it needs to be this way or the need for AutoCAD 2D inside of Inventor?  Share what sketching workflow you are struggling with that if AutoCAD was inside of Inventor it would make your life easier..    Meaning don't sound like you are complaining, share the struggles and that will help us understand what you are making these statments.
For my opinion..  I've used AutoCAD since release 9 and Inventor since 2008.  Yes maybe there was a couple of times some AutoCAD functions may have helped me when I started out but for the 10/11 years I've been using Inventor I never really wished AutoCAD 2D was inside of Inventor (but that's my opinion Smiley Wink)
Mark Lancaster
Message 14 of 16
in reply to: Curtis_Waguespack
I definitely understand and know that I will eventually get used to sketching in Inventor. It is always frustrating to change programs and I am early on in the process. And since I was posting to a 10 year old thread is it possible that Inventor has a format painter tool now? Please tell me I missed it.
mhogan
Message 15 of 16
Curtis_Waguespack
Hi milton.hogan,
Since you said please, I want to tell you that...but then Mark.Lancaster would say my "pants are on fire". So no there is not format painter, at least not in the sense that you're asking.
There is likely a way to do whatever you're after though.
Start a brand new thread and ask your question, and be specific about what you're doing:
  • is this the part sketching environment you're working in
  • or the drawing environment, and so on.
  • Post a screen capture if you can.
  • mention the version of Inventor you're using (2017, 2018) etc,
I hope this helps.
Curtis
Message 16 of 16
johnsonshiue
Hi Milton,
AutoCAD is a wonderful CAD program. We just celebrate its 35th birthday. There is nothing wrong liking AutoCAD. Do you have access to AutoCAD? You can still keep drafting in AutoCAD and then link the dwg file to Inventor via DWG Underlay workflow.
Inventor and its competitors are 3D feature-based parametric solid modelers specializing in aiding design for manufactured objects. The geometry created in Inventor cannot just look nice or look right. It has to be precise and logical. The geometry has to be within tight tolerance (10E-5mm) in order to serve as an ideal virtual build for manufacturing purpose. Sketch constraints and parametric dimensions help establish logical relationship between geometry. It may feel cumbersome at first. But, the ability to update geometry by changing parameter will save you a lot of redraw time.
Since you mentioned you used Solidworks before, Inventor should be fairly similar in terms of sketching. Could you give us specific examples that you have trouble with? Inventor is not perfect. Nor is any CAD on the market perfect. We always look for room to improvement.
Many thanks!
Software Test Engineer
