HPsteam,
Good afternoon! I'm sorry to read of your troubles with text copying, but it looks like you are correct, Inventor doesn't seem to have as many text variations as AutoCAD. However, there are a couple of ways to get the text into Inventor, formatted more to your liking.
- The first step is to delete the number in front of each line (or wrapped line) of text and then replace it with the Inventor number scheme. That seems to get all of the text to indent the same amount.
- The second approach is to create a block of the text(s) (create individual blocks for each text note) and then save the drawing in AutoCAD. Inside Inventor, expand the Drawing Resources Node in the Browser and then Right-Click on the AutoCAD Blocks folder to "Import AutoCAD Block". Navigate to the saved drawing and then insert whichever blocks you wish. It should show up in the roster of AutoCAD blocks and you can place from there. (Test this out on one before importing more, as it didn't allow for text font changes and may not look the way that you want it to)
These are more workarounds, but if you have any questions on them, please let me know and I can try to make a video demonstrating the techniques. Also, you may want to consider posting this to the Inventor Ideas to help improve the product. Based on your tag line, it sounds like Inventor may not have been your first choice, so don't be afraid to voice ways the software can be improved and hopefully it will continue to improve as you get more used to it. Hope this helps and have a most blessed day!
Peace,
Pete
Just a guy on a couch...
Please give a kudos if helpful and mark as a solution if somehow I got it right.
