No because you physically can't make it.
You'd have to make it in two sections and weld them together.
Probably the picture frame with the lower flanges on and then make the top piece as one folded ring that you weld onto the picture frame.
Either that, or you make the inside flanges on the front and rear edges narrower so that when you unfold it there's space for it to go. You'd have to shorten all the top ones as well.
You can't even split this in half and do it that way. What are you making this for?
Inventor Certified Professional
