Flat pattern from constructed shell (can't create flat pattern)
Hi, everyone i hope you are having a great day.
I've been struggling with a small problem (i hope) within Inventor.
I created a figured and made it my shell to create sides for it.
- This is to make pieces of plate for weld use later.
I want to create a flat pattern in order to "export face as" for a .dxf file
However i can't seem to make a flat pattern, hope you guys can help.
Jacob
Attached is my file.
CCarreiras
Well... there's some bit that inventor didn't like in your surface, so i had to create it again...
CCarreiras
Ok, so i guess i created it in some wrong way.
But thank you. This solves my problem for now.
- Jacob
johnsonshiue
Hi Jacob,
Another way is to use Mesh Mixer to unwrap converted mesh faces. Here is the workflow.
https://forums.autodesk.com/t5/inventor-forum/unfold-complex-surface/m-p/7249578/highlight/true#M652...
Many thanks!
Software Test Engineer
Ill try this method once i get home to my own machine.
Never tried meshmixer but looking forward to it.
- Jacob
@CCarreiras I would like to know, the process you went through?
It looks like you made a new square piece of plate, and then inserted the measures of mine.
Then recreated the fold over the middle, but i can't tell what the "splits" are for?
Thank you once again.
 -Jacob
CCarreiras
Well.... I created first a kind of a simple rectangular bended shape.
After i checked that shape could flatten, i did split and cut the rectangle to obtain your specific shape.
CCarreiras
