Inventor Forum
Pattern with Shell
5 REPLIES 5
ZaC-04
822 Views, 5 Replies
Pattern with Shell
I have made a pipe run as an .ipt file
1. Can a pattern be used which includes the Shell feature. I was not able to achieve with Pattern-1 as i could not select Shell feature?
or
2. I could pattern Revolution-1 and then follow with the Shell feature, then add Revolution-2 onto Revolution-1, then pattern Revolution-2
Are there other ways of creating Revolution-1, Shell And Revolution-2 and then pattern along Sweep-1 or do i need to use #2 above?
Thank you and 2018 attached
Zac
5 REPLIES 5
Thomas_Savage
in reply to: ZaC-04
You could make Revolution 1 a new solid, with Revolution 2 and the shell part of that solid.
Then when you pattern the solid, which will be Revolution 1, will take the shell with it. And Revolution 2.
Then if you need it to only be 1 solid again, combine them together.
I attached your file so you can see what i mean.
Hope this helps?
Thomas.
Thomas Savage
Design Engineer
ZaC-04
in reply to: Thomas_Savage
Thank you
The only problem with performing this way is that it leaves parts of the pipes inside the other pipe
Zac
Thomas_Savage
in reply to: ZaC-04
Sorry about that.
Another way you can do it is.
Just offset from the edges you wanted to shell, .1mm, or whatever thickness you wanted to shell.
And extrude cut, and sweep cut. Because you can pattern extrude cut.
Then do the sweep cut after.
I have attached a part with what i have done.
Thomas.
Thomas Savage
Design Engineer
johnsonshiue
in reply to: ZaC-04
Hi! Indeed, Shell is not patternable by itself. It is because it has to depend on a solid body. Thomas is right. You may consider moving Shell to the bottom after the pattern feature is created.
Many thanks!
Software Test Engineer
ZaC-04
Thanks Thomas
I had thought of performing that way as well but i was trying to minimize the number of steps. You have proved that the Shell in this example is maybe not the best way to use
Another thought: Could this type of Piping also be done with Tube'n'Pipe?
Thank you
Zac
