Flat pattern for hole in rolled surface
wowrs1608
Message 1 of 14
wowrs1608
The exported dxf has two different profiles for both sides. Is it possible to get the profile at the mean radius? So I could cut it?
I found one post close:
https://forums.autodesk.com/t5/inventor-forum/holes-in-curved-surface-flat-pattern-inventor-2014/m-p...
Pete
Replies (13)
Message 2 of 14
CCarreiras
Hi!
The link you refer to is very old, (it reminded me how long I am participating in this forum😅).... nowadays there are new options in the Inventor sheet metal module, that can do what you need directly.
Delete extrude (maintain the sketch)
Use Cut tool with the options in the image below.
Result:
Flat:
File attached.
CCarreiras
Message 3 of 14
wowrs1608
Thank you very much.
The Cut Normal is interesting. But I have a pipe go into this part horizontally. So the end result is not preferred.
Message 4 of 14
wowrs1608
Prefer this
Message 5 of 14
CCarreiras
The hole is made when the part is flat, or when the part is already folded?
CCarreiras
Message 6 of 14
wowrs1608
I want to cut the hole on the flat sheet, then roll.
Then a small pipe will be welded on to this part horizontally. The small pipe will has the right shape at the front end.
Message 7 of 14
CCarreiras
Your cutting machine is able to do a cut like this?!!! wow!!!
Well... in that case, you have to do it manually and follow the method shown in the "old" link:
Create the tube
Create the hole Witout the cut normal option
UNFOLD the part and use the holes as a reference to create the "mean radius".
REFOLD the tube to have the final folded part.
....but in this case you have to deform the tube to fit in the hole.
CCarreiras
Message 8 of 14
IgorMir
If your cutting machine is capable of performing 3D cut - then to model the part is simple. Here is a quick example (Part1) in IV2020 format.
If the machine of yours can only cut in 2D - then you are limited to Part2 version.
Cheers,
Igor.
Web: www.meqc.com.au
Message 9 of 14
wowrs1608
Only 2d cut.  So I am after one profile from the centre mean plane. Not the two profiles from both the sides.
ccarreiras has already provided part2 type. Not preferred.
I need the software to generate the cut profile along the center mean radius line for the dxf.
Message 10 of 14
IgorMir
In such a case - Part2.ipt sent earlier is what you can use.
Cheers,
Igor.
Message 11 of 14
swalton
I think the Cut Normal will be the fastest way to model something that will both pass a 20mm OD pipe and have perpendicular edges that can be cut with a 2d laser/plasma/waterjet.  The gaps between the formed part and the pipe can be filled with weld bead during fabrication to hide the odd tail from the tangent intersection.
If the smaller pipe could be moved away from tangent to the ID of the formed part, the resulting cut would not have the sharp intersection.  The further the pipe moves, the larger the curve.
I used surface modeling and the thicken command to cut the formed part at the midplane.  There are issues.  See attached.
Steve Walton
Inventor 2025
Vault Professional 2025
Message 12 of 14
swalton
Here is another version where the formed part is nicer to cut, but requires coping the smaller pipe to avoid any interference.   I used a surface model and some projected geometry to modify the cutout shape.  I used an obround, not a circle to trim the midplane.
I'm sure there is a cleaner way to model the intersection, but its late and I ran out of time...
I hope the two additional examples give you some ideas about modeling exactly what you want.
Steve Walton
Inventor 2025
Message 13 of 14
CCarreiras
Well, if you want to go that way, here's an example of the "mean" radius hole, and normal to face, to cut in the flat sheet.
File attached.
Adjusting the tube:
CCarreiras
Message 14 of 14
wowrs1608
The small insertion pipe will use template to cut into profile to join the big in horizontal direction.
