Inventor Forum
Flat pattern cuts
8 REPLIES 8
Message 1 of 9
dwenteiii
819 Views, 8 Replies
Flat pattern cuts
Didn't find anything in a search, so please link to a thread if it does reference this problem.
When creating cuts, sometimes the cut goes through a bend.  This makes the flat pattern have countoured edges, and the flat pattern has extra lines.  Is there a setting I can turn on so the cuts are limited to keeping a straight cut?  Please see image attached.
Inventor Professional 2017
8 REPLIES 8
Message 2 of 9
CCarreiras
in reply to: dwenteiii
Please, post the file.
Only with the picture is dificult to understand why it happends, we need to see how you cut to find a solution.
CCarreiras
Message 3 of 9
dwenteiii
in reply to: CCarreiras
The cut goes through the radius of the bend.  I can move the cut, but I'm curious if there is a setting which makes a straight cut through the thickness of the material without creating countours in the flat pattern.  This makes extra lines in the .dxf obviously.  I have limited access to licensing of AutoCAD to double check and edit these .dxfs.  And I don't always notice strange happenings in the flat pattern when modeling.  Thanks for your help!
Message 4 of 9
JDMather
You can adjust the chord tolerance for those in the DXF export.
Message 5 of 9
CCarreiras
Hi!
It's never a good idea to cut over the bends.
Check the video to avoid that.
https://dl.dropboxusercontent.com/u/108503790/face-bend.mp4
You can also use unfold tool, cut and refold to have also a good result.
CCarreiras
Message 6 of 9
dwenteiii
in reply to: JDMather
I'm not seeing chord tolerance.  I've got Linear tolerance under geometry tab and layers; but that's about it.
Message 7 of 9
dwenteiii
Thank you, I normally use flange.  Did you create a sketch from the edge of face1 with the dimensions of the flange and work from there?
Message 8 of 9
CCarreiras
Yes, in this case.
If you cut  thru the bends,it's not a good idea, sometimes you even can remove the conditions to flat the sheet, therefore is safer if you use the face+bend, or use other process: after create the flange unfold it, make the cut, and then fold it again.
CCarreiras
Message 9 of 9
JDMather
Yes, this is what I was referring to -
