Flat Pattern Breaks Alignment
leandropinhao
leandropinhao
I´m trying to align several views of a part on a inventor drawing.
This part is very long to fit on the page so I´m using several breaks, they auto align when the views are created with projected view.
The problem starts when I put the flat pattern, I can align the position but not the breaks.
So, I basically have all the projected views with the breaks aligned but not the flat pattern view.
Anyone have any sugestion how to do this?
Thanks.
CCarreiras
Hi!
You can give a vertical or horizontal align between the flat pattern view and other one projected view.
Then you have to make the breaks manually in the flat pattern and try the most to be equal to the aligned view's break.
CCarreiras
leandropinhao
Thanks for the fast reply.
Yes, that´s what I´m doing: align the flat pattern with a projected view and manually align the breaks in the flat pattern but if I use 4 or 5 breaks it´s almost impossible to align.
I tought there´s a way of doing this automatically.
brendan.henderson
A great idea to add to the Inventor IdeaStation : http://forums.autodesk.com/t5/inventor-ideastation/idb-p/v1232
Brendan Henderson
CAD Manager
New Blog | Old Blog | Google+ | Twitter
Inventor 2016 PDSU Build 236, Release 2016.2.2, Vault Professional 2016 Update 1, Win 7 64 bit
Please use "Accept as Solution" & give "Kudos" if this response helped you.
lars5GXWC
Anybody know if this was postede to the Idea station?
This would be a very nice option.
-niels-
I don't know if this exact request was posted, but if you follow the link in post #4 and search the board for "break align" you'll get several suggestions that seem related. (dimensioning breaks for instance)
Cast some votes on anything that seems like a good feature to you!
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
