Not sure if there is a bug going on, or if I am doing something wrong. When I apply a finish and click ok, then go to create a new finish I am not getting the option to use a preset or 'last used' and I also don't have the eye dropper option that is supposed to have been implemented in the 2024.1 release. I am currently running the 2024.3.1 release. I also checked the finish.xml document to make sure it is not set to read only, and it wasn't.
This is how my dialog box looks:
This is what I am expecting to see:
XML document:
Solved by kacper.suchomski. Go to Solution.
Hi
Check "Hamburger settings".
Kacper Suchomski
