Finding Recent documents for another user Windows 10.
I am using Inventor professional 2020 on windows 10 V1909 that I have full Admin rights to.
Had a coworker who left the job and didn't leave a note where his recent projects were stored.
I was hoping there was a file I could see their recent history of open files... I cannot sign in as his username as it is a windows domain account.
thanks in advance.
Gabriel_Watson
Try this:
https://blogs.rand.com/support/2016/06/inventor-home-tab-remove-items-from-the-recent-documents-list...
But use "HKEY_USERS\<anySID>" while signed on as an admin, instead of the below "\HKEY_CURRENT_USER\":
HKEY_CURRENT_USER\Software\Autodesk\Inventor\RegistryVersion24.0\Recent File List
(version 24.0 above is for Inventor 2020 I believe... it varies depending on your Inventor version)
I tried Remotely and I could not see their user SID listed in the registry...
I'll have to try again later as local admin.
I will report back either way! Thanks.
SharkDesign
I'm assuming you use a different project file for each project?
Can you just search for IPJ files on the network drive where all your work is stored and then filter them by date?
  Inventor Certified Professional
I tried as local admin and wasn't able to see the SID listed in the registry. So I will have to revert to filter by *.ipj files.
I was hoping for a magnet to help me find my "needle in a hay stack"
