So we do a-lot of steelwork manufacturing at my workplace ( I'm aware of Revit), often we have one component that has the bolt holes and use the bolted connection in the top level assembly down to the lower assembly parts. No bolts or any hardware are added to the model when making the bolted connection, it is just to get the hole into the parts to make drawings from. So when i click on a bolted connection in the browser tree nothing is highlighted because there is nothing in these bolted connection assemblies.
I want to be able to click the bolted connection in the browser tree and easily show in the model where that connection is. At the moment i have to expand the bolted connections and click on the mates that have been automatically generated within the bolted connection assemblies, some of my main assemblies have like 50 bolted connections so it can be annoying.
Also i want to be able to click on a hole made by a bolted connection in the model (by selecting feature priority) and have that bolted connection highlight itself in the browser tree which is does not because there is nothing in my bolted connections.
And lastly this is another issue with the bolted connection, we cannot just simply leave it as boltedconnection1.iam, we have to manually add on the assembly number boltedconnection1-A01402.iam before we can save to vault because we get clashes, is there a way similar to the frame generator automatic part number generator inbuilt into inventor for bolted connections? at the moment i believe there is not.
If you could answer these questions and query's it would be greatly appreciated, thanks.
