Find unvisible component problem at large assembly
cetin_yildirim
cetin_yildirim
ıf  you  have  large assembly and  you need to turn of some  component  visibility or  like this you can not  find this component easily.
We can use "find component " tools  but this  tools  not  enough because ıt doesn't show the unvisible component at browser one times, we have to expands all files  at browser.
I  wish this tools will be developed...
Curtis_Waguespack
Hi cetin.yildirim,
This might not completely address the issue you're speaking to, but it might help in some instances such as constraining two parts:
Rather than using visibility and turning off components, you can select just the components you want to stay on (typically the two components you're wanting to constrain together) , and then right click and chosoe Isolate.
Then place constraints as needed, and then right click and choose Undo-Isolate.
Beware, though that you do not want to mix the Isoalte and Visibility tools. For example, if you Isolate some components, and then use Visibility to turn one of them on/off, you will have stepped on your Undo-Isolate option.
More on Isolate:
http://help.autodesk.com/view/INVNTOR/2015/ENU/?gu​id=GUID-9D872034-6321-40EE-9A93-1FC5F0C1BC2A
I hope this helps.
Curtis
cetin_yildirim
isolate command can use but ıf you ısolate more than one component and want to unisolate one of this component how can choose component?
