Inventor Forum
fillet
6 REPLIES 6
597 Views, 6 Replies
fillet
I have a problem in doing fillet.
P2 middle is a part that do not have fillet. (See attached part)
When I apply fillet command (R=300), the top part will be cut. (See P2 middle with fillet)
Is there any way that it will never cut the concrete when I apply fillet?
Thanks in advance.
6 REPLIES 6
SašoPrijatelj
A variable fillet might be a solution for you. See attached part.
AutoDXF - automatic flat pattern creation and batch export to DXF for Inventor
Please use "Accept as Solution" & give "Kudos" if this response helped you.
in reply to: SašoPrijatelj
Thanks for your reply but I need top & bottom radius is 300.
Your drawing is top radius is 0 then bottom is 300.
Regards
SašoPrijatelj
Do you maybe have a photo of what exactly you want to achieve?
Hi. See attached.
MingweiGao
I just saw your more information and I'll look at it.
Steven Gao
Principal Quality Assurance Engineer
MingweiGao
in reply to: MingweiGao
Is your problem for the fillet of this drawing?
BTW: You may not need the loft feature to do the major body and just use extrusion and cut the redundancy.
Steven Gao
