- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I often have difficulty creating the correct radius fillets in my models. I either get an error message indicating the geometry is too complex or Inventor will not create a large enough radius fillet.
In the Cleat model below, the fillet radius at the ends of the two horns should be 5/8". The largest fillet radius inventor will create is 7/16" Why? This is a problem. Like this cleat, I sometimes recreate models that were original created in Solidworks and Inventor doesn't seem to be capable of creating the same model. Am I doing something wrong? Is this a limitation of Inventor Professional 2021? Need some help to sort through or work around this issue.
I can upload the .ipt file if that will help. Let me know.
Thank you,
Cleat with Incorrect End Fillet Radius
