Inventor Forum
fillet help
5 REPLIES 5
460 Views, 5 Replies
fillet help
how do you get a fillet to go through two separate extrusions, how do i get the fillet to look like the first photo (green), instead of the second photo (red), where the fillet cuts off after one extrusion. please help, thank you
5 REPLIES 5
JDMather
Can you Attach your *.ipt file here?
in reply to: JDMather
attached below, thanks
JDMather
You should install the latest Updates for 2018, while I take a look at possible solutions.
Because you have a taper on Extrusion1 - if you zoom in close you will notice a difference with your arc.
My first guess is going to be Face Fillet rather than Edge Fillet, but I need to do some testing...
JDMather
See Attached.
thank you!
