Fillet Fails - Complex curve
tfarllc
tfarllc
The fillet function fails.  I created an extrusion using lines from a dxf file.  I closed the curve first then created the extrusion (see Thicker padding extrusion in the attached model).  Next I tried to create a fillet (1.9 mm) using the command fillet command in the 3D Model tab.  I probably got the fillet to go 80% of the way around.  Where the fillet failed I would try smoothing the sketch curve that creates the extrusion.  I actually made the problem worse.
   Any ideas on how to create fillet all the way around  the edge of "Thicker padding" extrusion?
I tried sweeping but that also failed.
Using - AutoDesk Inventor 2017
With such a complex design, I would first look at the DXF data. Is it indeed a closed loop. Any chance you have multiple lines that cross back on themselves. Things I have done is try to break up the sketch into sections and perform what you want to do. If it works, then undo back and try a different section to find where it breaks. The fact that the top fillet is in a section tells me that your profile is not closed or well defined. I don't mean dimensioned, just not well defined.
tfarllc
Thank you for your input.   The dxf was a mess to start.  I picked "close loop" and closed it.  Additionally, I tried fillet and create arc's  inside the sketch mode to smooth the curve.   This method gave me hope but what gains I made I started losing.
     In that model I posted there is Extrusion 5 - Spline Curve.   I hand sketched a spline around the dxf curve.  The spline looks smooth except for the start/end point.  I could not fillet the Extrusion 5 either  so I suppressed it.
   I am a bit confused.  I can't seem to pick a small enough section of the curve to fillet.
tfarllc
The best solution at this point was to use the hand sketched spline curve and extrude.  This curve left an irregularity at the start/end point.  I put some effort into smoothing the spline there.  Next,  I created a fillet with a tiny radius (.1 mm).  Slowly I increased the radius.  Where the radius failed I would reduce the increment and try again.  This method resulted in something of practical use but a mine field to someone trying to alter the model.
