I haven't been able to find anyone else dealing with this, so it might just be a weird setting on my end. I am trying to create a fillet between the end of a rib and the bottom face of a shell in my actual part. Instead of staying within the width of the rib, the fillet extends the full width of the part. I have tried several options and fillet sizes and have not been able to get it to work as I expected in Inventor. Recreating the part in Solidworks, the fillet tool behaves as I expect. Screenshots are attached, and I'm attaching the example Inventor file. The model tree is identical in both programs, the base extrude, then a midplane, extrude to create the rib, and finally the fillet.
I could add an extrude to remove the unwanted portion of fillet, but that seems kind of kludgy.
Solved by johnsonshiue. Go to Solution.
Solved by mluterman. Go to Solution.
Sometimes, I just draw the fillet on a 2D sketch (arcs and lines) and extrude it rather than using the actual "Fillet" command itself; that command can be finicky.
Very well demonstrated... please vote here:
https://forums.autodesk.com/t5/inventor-ideas/extention-limits-for-fillet-partial-fillet/idi-p/63428...
And maybe post your example to illustrate this other similar idea:
https://forums.autodesk.com/t5/inventor-ideas/fix-the-inventor-fillet-command/idi-p/11591280
CAD and PLM admin | My ideas | Inventor-Vault Expert GPT (my AI brain)
@mluterman Your solution looks like the best one currently available, so I'm marking yours as accepted.
@Gabriel_Watson Voted for both, was able to add the screenshots to the second one in a post, but couldn't figure out how to attach the .ipt file so used the permalink to link back to here.
Hi! This is currently a limitation in Inventor's modeling kernel, shared by multiple ADSK products. The issue here is that the selected edge is on a face shared by the adjacent edges. The Fillet operates on the entire side face.
To get the desirable result, you may want to split the face as shown in the image.
Many thanks!
