File Translation Error - From Solidworks 2017 to Inventor 2018.2.3
Aadithya01
Advisor Advisor
Message 1 of 10
Aadithya01
Hey Guys,
Please see the below video which clearly shows the error in File translation when a solidworks model is opened in both Inventor as well as Fusion 360 ...
Please have a look at the video and also I have attached the Solidworks file for your reference ..
Regards
Aadithya
Application Engineer - USAM Coimbatore
Replies (9)
Message 2 of 10
Xun.Zhang
Hi Aadithya,
This is a defect indeed, the shape is not generated correctly from shape kernel.
Forwarding to shape kernel team from now on.
Thank you again!
Xun
Message 3 of 10
TheCADWhisperer
The SolidWorks file opens in SolidWorks indicating a missing reference.
 Do you have access to the original *.sldprt file?
The STEP file opens in SolidWorks indicating errors in Import Diagnostics.
The part has a poorly defined face.
Message 4 of 10
Aadithya01
Hi @TheCADWhisperer
I remember that my customer had this original file like a Multi Body part (he was doing Core and cavity design) ... where one of the body, he derived it as a part and gave it to me .... Like Inventor Make Part and Make components option there is a similar feature in Solidworks I guess ....
I don't have Solidworks at my end...  Also the surface that you have indicated .... Is it showing it as a unhealthy surface ...
I called the customer but he didn't pick up the call. It is almost 6.30pm in India ... Surely by tomorrow I will go to his office and I will get you the original file.  .
Regards
Aadithya
Message 5 of 10
Aadithya01
Hi @TheCADWhisperer@Xun.Zhang
Herewith I have attached the original Solidworks file of my customer's . Kindly help me ..
Regards
Aadithya
Message 6 of 10
TheCADWhisperer
I do not have a *.rar extractor installed on my clean Inventor/SolidWorks machine.
Message 7 of 10
Aadithya01
Hi @TheCADWhisperer
Thanks for your reply . .
Please see the attached sldprt file .
Regards
Aadithya
Message 8 of 10
TheCADWhisperer
The first node of the SolidWorks *.sldprt file indicates that this geometry was imported from some other source into SolidWorks.
I suspect the original geometry was poorly created - but without the source file I can only go by personal experience.
Based on my personal experience I would make a significant wager that the original geometry was poorly modeled.
The geometry is pretty simple - I would use this source geometry only as reference in properly modeling the part(s) from scratch.  (should take less than an hour of work)
Message 9 of 10
Aadithya01
Hi @TheCADWhisperer @Xun.Zhang
I have analysed this problem further more ... Please see the below screencast video and hear it with audio output.
Looking forward for your reply
Regards
Aadithya
Message 10 of 10
Xun.Zhang
The problem was identified and tracked by ticket ASM-5555.
Thanks!
Xun
