I want (2) identical directories in the same project. I have a directory that contains (2) idw's that reference (1) assembly in the same directory. Now I want a duplicate copy of that same directoy in the same project so I use design assistant to copy the idw's to its new directory. when I go to open those idw's they are still referencing the old directory so copy the assembly file over to the new directory using DA and it's fine for (1) of the idw's. The problem is that when I open the other idw in the new directory I can't replace its assembly that refrences the old directory. Am I missing something here?
