File name with browser nod
alex.salvadorTD52Z
Observer Observer
Message 1 of 8
alex.salvadorTD52Z
Observer
Observer
how i can rename files (ipt, iam) with broser node name?
 When i make a importation of outers software browser nodes have the name of origin software, but save files, it is with part01...
Replies (7)
Message 2 of 8
freierfall01
i worked and tryed a lot of different way to change the file name. And since 10 years i only use Vault Basic on one computer and one person. for the IPropertys you need Vault Prof.
Message 3 of 8
Logos_Atum
Actually there´s a function called "rename browser nodes"- that might just be it
Dogs aren´t flammable.
Message 4 of 8
alex.salvadorTD52Z
Observer
Observer
This function rename the nodes with the file name!
What i need is the opposite! rename the file with the name node!
Message 5 of 8
Logos_Atum
ARE YOU TERRY PRATCHETT´S DEATH- HE SOLEY TALKS IN UPPERCASE, and his apprentice maybe.
You got three choices in "renaming browser knodes" I thought
part number
file name
the browser´s default
You can rename them to either.
I am still trying to get to the bottom of your request
Message 6 of 8
alex.salvadorTD52Z
Observer
Observer
Sorry for "upper case"
Message 7 of 8
Logos_Atum
You want all the parts and sub assembly files renamed according to what they´re named in the browser? I can´t remember any batch file or iLogic snippet for that. Still this probably works even though I don´t know where to implement that. I asked the same question years ago I guess, but there was a way around that rendered doing this unnnecessary.
Message 8 of 8
johnsonshiue
Hi Alex, If you want to rename the file names based on the browser names, the best tool to use with a PDM (Vault) is Design Assistant. You may open the assembly in DA and rename the file names manually accordingly.
Many thanks!
Software Test Engineer
