File name of sheet metal part's flat pattern produced by inventor goes different
Rishi-Bhardwaj
Message 1 of 12
Rishi-Bhardwaj
Dear Inventor Users,
                                             I am facing a problem with inventor.
Here, I have attached a screenshot, to understand problem better.
I have created a (multibody) base part first and then by using make components, I have created separate-2 parts to get the flat pattern.
Till this point, everything is fine. But, now when, I am trying to produce flat pattern in dwg format. Save as name differs from the derived part name. It again works fine when; I am saving it as a dxf.
To get the desired result, I have to manually edit the name of dwg file, which is cumbersome and may leads to mistakes.
This type of Inventor's strange behavior is new to me.
I have also attached a 2nd screenshot here for reference.
If there is anything, please let me know.
Replies (11)
Message 2 of 12
王承之pmhker
I'm sorry I didn't understand you
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
如果我的回帖解决了您的问题,请点击 "接受为解决方案" 按钮. 这可以帮助其他人更快的找到解决方案!
王 承之
Autodesk AGN [Inventor 俱乐部] Leader
Inventor Club | Bilibili
AGN L    EESignature
Message 3 of 12
A.Acheson
In 2020 Version I am not seeing this, it may be unique to 2023. Can someone else check this?
Regards
Alan
Message 4 of 12
pcrawley
I might be missing a step, but I don't see the problem in 2023 using the following steps:
  1. Make & save a part with two bodies in it.
  2. Name the bodies PRP-16-A1-P3.3 and PRP-16-A1-P3.4
  3. Make Components
  4. Open PRP-16-A1-P3.3
Here's where I may have gone wrong:
  • Right click the flat face of PRP-16-A1-P3.3
  • Export Face As
  • The name field is blank (as I would expect)
I also tried:
  • Create Flat Pattern
  • Right Click the Flat Pattern in the browser
  • The name field is correct
(As a double-check, PRP-16-A1-P3.4 also worked correctly.)
Peter
Message 5 of 12
Rishi-Bhardwaj
Change the save as file type from dxf to DWG.
And than, it creates a problem.
While working with dxf it works fine.
Message 6 of 12
Rishi-Bhardwaj
Really sorry to you sir.
But, I am not a native English speaker.
That's why my English is not so good.
Message 7 of 12
Rishi-Bhardwaj
But again thanks for your first reply and time.
Message 8 of 12
Rishi-Bhardwaj
Thanks for your time sir...
Message 9 of 12
pcrawley
Your English is significantly better than my Hindi!
Unfortunately, I still do not have a problem exporting to DWG either.
Which version of Inventor are you using?
Can you post a sample file that demonstrates the problem?
Peter
Message 10 of 12
Rishi-Bhardwaj
I have inventor 2023.2
I will share files with you tomorrow morning.
Actually it's midnight in India.
Message 11 of 12
Rishi-Bhardwaj
Sir, I have attached sample files here.  Please have a look.
Can, I show my PC to you online if possible.
Then, I think we can better understand the problem.
Message 12 of 12
pcrawley
Hi @Rishi-Bhardwaj - Sorry, I cannot make this fail.
It is possible the missing parent file (PRP16-A1-P3.ipt) causes the problem, but if I ignore it and open PRP16-A1-P3.3, then export from the Flat Pattern, the DWG file name is correct:
I tested the other two files (PRP16-A1-P3.1 and PRP16-A1-P3.2) and they also work as expected.
Peter
