Inventor Forum
File is lost
7 REPLIES 7
Message 1 of 8
323 Views, 7 Replies
File is lost
When I make a tapped hole I get this warning.
Can someone help me?
File is lost
7 REPLIES 7
Message 2 of 8
WHolzwarth
WHolzwarth
Is Thread.xls existing at the location shown above?
Walter Holzwarth
Walter Holzwarth
Message 3 of 8
Xun.Zhang
Xun.Zhang
It seems the thread file is missing, please navigate to the location and check if the file still there?
Else, you have to copy one from other machine.
Thanks!
Xun
Thanks!
Xun
Message 4 of 8
in reply to: Xun.Zhang
I'm searching for the //VAULTSERVER folder but I can't find it
Message 5 of 8
in reply to: WHolzwarth
Message 6 of 8
mdavis22569
mdavis22569
Find it on your local drive .... and then share it back up to the Vault location where you have your Design Data stored ....
Mike Davis
Mike Davis
Message 7 of 8
mdavis22569
mdavis22569
Find it on your local drive .... and then share it or copy it back up to the Vault location where you have your Design Data stored ....
Mike Davis
Mike Davis
Message 8 of 8
SBix26
SBix26
Did you change your active project accidentally?
Inventor is looking for your thread file under the Design Data folder designated by your active project file (.ipj); this is either Default (defined by Application Options > File > Design Data) or as explicitly defined by your active project (File Options > Design Data).
If it was working previously, then I suspect an inadvertent change of active project file.
Sam B
Inventor Pro 2019.3 | Windows 7 SP1
LinkedIn
Sam B
LinkedIn
