Inventor Forum
File Association between 2d and 3d
5 REPLIES 5
258 Views, 5 Replies
I am using AutoCAD Design Suite Standard 2014. My question is a simple one but not for me apparently, How do you make the 3d model in inventor reflect drawing changes made in 2d? Thanks,
5 REPLIES 5
JDMather
I am not sure I understand.
The 2D is derived from the 3D.
What are you changing in the 2D?
You can Retrieve Dimensions and use the Model dimensions in the 2D to edit the 3D.
Better attach an example (your 2D and 3D) to illustrate exactly what you are trying to do.
in reply to: JDMather
Actually in this case we have old AutoCad 2d drawings that need to be converted to 3d. So I opened my 2d drawing in mechanical, copied/pasted into a 2d sketch in Inventor. From that sketch I derived the 3d by rotating around an axis. I assume that somehow I need to reference the detail 2d drawing in inventor if that's possible?
JDMather
I would seldom copy and paste from AutoCAD to Inventor (especially for beginners) as the AutoCAD was frequently not done correclty.
Did you dimension and constrain the 2D sketch in Inventor after pasting?
Create associative 2D dwg or idw in Inventor from the ipt.
Forget the obsolete 2D AutoCAD moving forward.
Attach your files here if you can't figure it out.
Curtis_Waguespack
Hi Oakcutter,
You can create a link to the original *.dwg file by going to the Manage tab > Insert panel > Insert Object button. This tool allows you to place a 3rd Party node in the browser that will contain a link to your original file. It will not be an associative reference though. Meaning that if you were to delete some of the geometry in AutoCAD, it will not update the Inventor file. But it will allow you to document the source drawing in your Inventor file.
I hope this helps.
Curtis
in reply to: Curtis_Waguespack
Thanks for your input, I do appreciate all the help I can get.
Oakcutter
Autodesk Customer Advisory Groups
