Field Text read-only
tmccar
Advisor Advisor
tmccar
When I insert the title block in the drawing the first time, I can edit the field text but after that it becomes read-only. How can it be made editable?
James_Willo
Hi, can you show what you are doing?
If you have a prompted entry field on place, you should be able to edit that by right clicking field text and choosing edit in the browser.
James W
Inventor UX Designer
tmccar
It was not all read-only, just 2 fields - "Project" and "Revision" and I have since discovered that they are set in iProperties.
