FEM Analysis on Steel Wires
vkulikajevas
vkulikajevas
I am looking for a best way to run analysis on Steel Wire support. Structure height is 5-6 m.
It has a support from 3 steel wire cables.
I need to find how rigid the system will be using certain wire gauges and sizes.
Can anyone help me the best way to run simulation?
The problem is how to model the cables? Should they be done as a cylinder with Sweep operation? Will this work?Example 01.jpg
JDMather
The only way you will get anything close to useful information is to use the Frame Generator and Frame Analysis with beam elements.  Wire rope isn't the same as a Frame Generator component, but might at least give you some ballpark behavior.
vkulikajevas
But the nature of steel wire is its flexibility. You don't have that with a beam of steel.
It is somehow amazing, how Inventor (Including Solidworks too) after 20 years doesn't have Steel Cable Feature.
hosford
Just a thought.
Because steel cable can only be useful in tension, why not test a 2D model where the cable is in tension using a strut of equal strength in tension?
Thaddeus Hosford
NUC9i9QNX i9-9980HK, Win 10 Pro 64
Nvidia GTX 1650
Inventor 2021
KakaSungura
I would use Autodesk Nastran for this.
To model the steel cables, I'd create a part by sweeping along a path, then set that part's iProperties to the type of steel you want. So yes, your suggestion on how to model the steel cables is right, according to me.
PS:
Are you talking about this kind of cable?
Steel_Wire_Rope-1280x720
An approximation (using a cylinder) is enough. You don't have to model the individual strands. Engineering is lots of approximations.
Nikishika mouse wanajua ni mazishi!
vkulikajevas
Thank you for your reply. Yes you have the right picture of cable.
The thing I think it is important to get into account the flexibility of cable.
Take 1 m of 1 cm^2 section Steel rod - Bend it,
and take 1 m of 1 cm^2 cable - Bend it. I am betting you, that you will get much better bend results in the cable than in a rod.
In my situation, I have tower which is supported by 3 cables, 2 cables will be in tension and 1 will be in compression (Forces shift of course, but the Cable - rod under compression would not get the results I search for, and make construction much more rigid that it is in life).
Do you understand now, that the flexibility in these configuration differs a lot, that is why you will get different results in calculations. And approximations in this case is really big. Unless there is a way to define higher elasticity to the material itself, and make it's property to act as a cable? In this case, that might just work.
Maybe there is a way to do that?
Assign a Steel Wire - Cable Elasticity to certain rod extrusion for Stress analysis to treat them as cable?
swalton
I believe that Inventor Nastran (available in the Collection) is a better tool for this type of problem.  It has a cable element, which the Inventor Professional FEA tool does not.
See: https://knowledge.autodesk.com/support/inventor-nastran/learn-explore/caas/CloudHelp/cloudhelp/2018/...
I'd do a few tests to make sure that the behavior of the cable element matches your expectations. (Only tension loads, no compression loads)
I would not rely on the stiffness of your steel cable to carry any compression loads in the real world.  I'd expect the cable to buckle or kink under a real-world compression load.
Steve Walton
Inventor 2025
Vault Professional 2025
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
