Inventor Forum
fem analisys
3 REPLIES 3
C_AmourCoind
128 Views, 3 Replies
fem analisys
C_AmourCoind
How can i set FEM parameters for a stailess tank filled with water?
Clearance between sheet metals must be zero?
I have to exclude welding from simulation?
 thanks at all
fem analisys
 thanks at all
3 REPLIES 3
swalton
in reply to: C_AmourCoind
swalton
What questions are you trying to answer with the FEA?
The basic Inventor FEA solver is limited to linear, small displacement problems.  It has pressure loads, but does not have a hydrostatic load.  It does not understand the physics of welds, so if you are interested in distortion, heat affected zones, or other fine details, you will need to use a different FEA package.  Inventor Nastran may fit the questions you are asking of the model.
Anyway, you might consider using shell elements for a thin-walled tank.
Steve Walton
Inventor 2024
Vault Professional 2024
Steve Walton
Inventor 2024
Frederick_Law
Find max pressure in the tank and use it to run FEA.
C_AmourCoind
Thanks so much!
Thanks so much!
