Inventor Forum
features and circular pattern
4 REPLIES 4
331 Views, 4 Replies
Hi!
I need to do extrude based on the this shapes.
There should be 18 arcs tangent to each other.
I want  to use exreude  and then create circular pattetrn using these features.
This is what I get:unaligned.png
My question is how do I calculate the dimension of the first feature, so the others will be tangent  one to another
Thank you!
4 REPLIES 4
Here is the file:
mcgyvr
360/18 = 20 deg
in reply to: mcgyvr
Here is another way
Make your Circle
Now your Arc
Now Pattern your Arc with 18ul
As you can tell the Arc's are not tagent to one another.  to make them tagent.  Select the 2 points of adjacent Arcs and make the value 0
then simply extrude or loft to the required length
in reply to: mcgyvr
@Anonymous, thanks for reply,
but method of @mcgyvr is best for me since I want to extrude the feature and not the sketch.
Thanks!
Technology Administrators
