Feature needed - iLogic Security "Folder" location (Inv2026.1)
I'm upgrading from Inv 2023 to 2026 and an issue I'm running into is a new iLogic security threat scan. I've found that I can completely disable this rule, but a feature I find lacking is the ability to select a particular folder location to "trust" like I can with AutoCAD.
I intentionally store master templates for use outside of the Project Path so that an alert will pop-up if they attempt to save over these files (non-vault system). The iLogic Security feature allows me to select the specific file being run; but as I have several sub-folders and files, the inability to add a folder location leaves me without an option other than to disable this scan.
We use a custom automation routine to assist drafters with rapid assemblies which pull from these master templates and due to the external routines, these security pop-ups are invisible to those routines and is causing failures.
If I'm overlooking a way to add a folder location, would appreciate that pointer.
