Feature needed - iLogic Security "Folder" location (Inv2026.1)
llorden4
llorden4
I'm upgrading from Inv 2023 to 2026 and an issue I'm running into is a new iLogic security threat scan.  I've found that I can completely disable this rule, but a feature I find lacking is the ability to select a particular folder location to "trust" like I can with AutoCAD.
I intentionally store master templates for use outside of the Project Path so that an alert will pop-up if they attempt to save over these files (non-vault system).  The iLogic Security feature allows me to select the specific file being run; but as I have several sub-folders and files, the inability to add a folder location leaves me without an option other than to disable this scan.
We use a custom automation routine to assist drafters with rapid assemblies which pull from these master templates and due to the external routines, these security pop-ups are invisible to those routines and is causing failures.
If I'm overlooking a way to add a folder location, would appreciate that pointer.
Autodesk Inventor Certified Professional
johnsonshiue
Hi Leo,
This is a very good idea. Please feel free to submit it to Inventor Ideas forum (https://forums.autodesk.com/t5/inventor-ideas/idb-p/inventor-ideas-en). In the meantime, I am forwarding it to the project team for further review.
Many thanks!
Software Test Engineer
MjDeck
Hi @llorden4 - there's no way to do it now. We might be able to add this in future.
If you are ready to designate an entire Project as trusted, then you could set this templates folder as a Library in that project. Then the trusted designation would extend to that library.
Mike Deck
Software Developer
Autodesk, Inc.
