FEA hollow surface and mesh continuity
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm facing some peculiar issues when I slice out an FEA model. Though it was created as a solid part in Inventor Solid modeling, the part turns hollow and I don't see mesh continuity between surfaces.
Second, when there are mesh continuity from one surface to the adjacent surface, I see the solution shows extreme singularities. Can some one help me understand what is causing this issue, and how can they be rectified.
I run much more complex geometries in real-time, but I created a basic simulation model to show what's going on. See attached picture, two 3x2x0.5" solid bars with 0.5" inch hole bolts are assembled. One of the surfaces is subjected to load, causing surfaces to rub and bolt to shear if the magnitude goes extreme. For simplicity I haven't included bolts and this is just a simple trial to indicate the issues, i.e., the geometry/ force are not realistic.
Thank you.
