Doing a static load analysis - nothing fancy here. Getting a "Internal Error: Regularization Failed" error.
Happens when I do Automatic Contacts or try to run the simulation.
What the heck does that mean & how is it fixed?
Thanks to anyone who can help here.
Hi Marshallw,
I Have seen this before with Thin Bodies, Try Running the "Thin Bodies" Command to identify any parts that MIGHT be considered Thin.
I Think its a problem with the Mesh, you could also try change the local Mesh settings on the member that might be considered thin.
The only Other time I have seen something like this was with a "home made" Material and someone forgot to add the Physical Properties.
Not sure if either of those help, but those are the only two times I have seen a "Regularization error".
James
Hi Marshallw,
James
The error message indicates that there is some issue in the geometric pre-processing. This step happens before contact detection. The problem could be dataset specific. If you can send the model, we can take a look.
Please also see the discussion here: http://forums.autodesk.com/t5/Inventor-General-Discussion/Meshing-error/m-p/5188005#M517097
Ravi Burla (Autodesk)
Just a point to this, I was getting the same error, even though I had excluded 90% of the assembly parts to drill down to only the important parts. When I performed a pack & go (still got the error on the pack & go assembly initially) I then physically deleted the parts that I had excluded previously and the simulation ran fine. This suggests that simply excluding a part from the simulation isn't as complete as it apears.
I can confirm this. I had a sheet metal weldment where I got "Regularization Failed" when building the mesh. I tried to change the mesh settings but could not make it work. It was only when i completely deleted some already excluded bearings that the error was gone. Its obvious that excluded components still are playing around with the meshing.
I'm running Inventor 2020.
Well no need to delete them, you just need to change your workflow.
Make a Level of Detail and make sure that is active, before you start the solver.
Parts that are already suppressed in the assembly will not show up in the Solver ( built-in and Nastran).
It will bring in only unsuppressed parts, then you can generate the mesh. ( along with the rest of the setup- but the mesh was the issue here)
This way you don't need to delete parts from the assembly to run the solver.
That said its always a good idea to have a Solve copy (FEA Copy) vs a working copy (Design / Production Copy), mostly for vault as those solves can get rather large. Trust me you don't need or want the 200Mb files attached in vault.
