Inventor Forum
FEA analysis and bolts
4 REPLIES 4
Stian
360 Views, 4 Replies
Stian
Fixed in the rear plate, 3000kg along the beam as seen in picture. I have zero MPa in stress in the rear bolt. Any suggestions? The force on beam will make it lean forward, giving stress output on the bottom and towards the area that are fixed. Why do I get zero stress in the bolt in the rear?
4 REPLIES 4
Stian
in reply to: Stian
Stian
Added last picture. I can upload this in STEP if anyone is intrested
JDMather
in reply to: Stian
JDMather
STEP will not demonstrate your set-up for the analysis.
Attach native Inventor files.
Fasteners are normally removed from analysis - are you attempting to analyze the fasteners or are you attempting to analyze the assembly?
mikejones
in reply to: Stian
mikejones
What contacts do you have in place? Can you upload a pack and go file for the assembly, that way someone here will be better able to help you out?
Mike
Autodesk Certified Professional
Mike
Stian
in reply to: JDMather
Stian
Well, the hole assembly, where the bolt is a part of the assembly. So, both the bolt and the assembly. Do I need to seperate these two parts?
Its just a quick test to see how it holds up.
This is a project for customer, so it breaches the confidentiality agreement if I upload it. Its kinda far fetched to ask for help without uploading files, but I made a try.
