Fatal error
Fatal error
Fatal error
how to fix: the transaction manager failed to start
Failed to create memory-mapped file used for scratch data
jhackney1972
Take a look at this Autodesk Webpage for solutions.
John Hackney, Retired
lena.talkhina
Hello @Anonymous  !
Great to see you here on Inventor Forum.
Did you find a solution?
If yes, please click on the "Accept as Solution" button as then also other community users can easily find and benefit from the information.
If not please don't hesitate to give an update here in your topic so all members know what ́s the progression on your question is and what might be helpful to achieve what you ́re looking for. 🙂
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям! | Do you find the posts helpful? "LIKE" these posts!
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
Лена Талхина/Lena Talkhina
Менеджер Сообщества - Русский/Community Manager - Russian
charlesKUCZ3
This solution is not working. Can someone advise what to do? My inventor will not open as a result. INV 2019.
johnsonshiue
Hi Charles,
Do you mind elaborating the exact issue you are seeing? If Inventor does not run at all, it is probably a licensing service issue. Please install the latest licensing update.
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/Autodesk...
And, install the latest Inventor update applicable to your release.
Many thanks!
Software Test Engineer
charlesKUCZ3
Unless im missing something, there are no licensing updates or program updates available for 2019 any longer.
The issue i am having is the below error when attempting to launch inventor 2019
johnsonshiue
Hi Charles,
The error dialog seems to be a known issue. Please take a look at the following article.
https://knowledge.autodesk.com/support/inventor/troubleshooting/caas/sfdcarticles/sfdcarticles/Inven...
Many thanks!
