Fastener Information in a Drawing Hole Table
ShayaGhanbar
ShayaGhanbar
In an Inventor drawing, has anyone noticed that even though there are columns (Fastener Fit, Fastener Size and Faster Type) available in a hole table the columns come with no information?
If a part has fasteners, the hole table only shows information regarding the hole and not the fasteners even though that fastener info columns are available.
Shaya Ghanbar, P.Eng.
Technical Specialist - MFG
SolidCAD - A Cansel Company
HermJan.Otterman
Hello Shaya,
I hope that the pictures explane it
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated Smiley Wink
Succes on your project, and have a nice day
Herm Jan
ShayaGhanbar
Hi Herm,
What you have is correct and works only for clearance holes. How about tapped holes?
Shaya
mcgyvr
@ShayaGhanbar wrote:
Hi Herm,
Shaya
What would be the point for tapped holes?
The thread already specifies the "fastener size"..  There is no "fit" for threaded holes.. and the "fastener type" is used to default it to c'bore/c'sink options during hole creation...
blair
On a straight hole I've never really seen the need to supply fastener information at the part/hole level. Since you don't have any hardware at the part level, this information should be at the assembly level where the fasteners reside.
The only information should pertain to what's in the IPT and not what's going to be in the IAM.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
