Colored Piping Design
mmbguide
mmbguide
hello everybody
How can I have a colored Tube and Pipe Styles in Autodesk Inventor.
I want to have different color of pipe with different colors for fittings and equipments in my pipe design. for example: Flange (Color 1), 90 Deg. elbow (Color 2), 45 Deg. Elbow (color 3),... which are created by pipe routs. I do not want to change them one by one.
thank you
Mark.Lancaster
@mmbguide
Are you saying that for each pipe run you want an individual color assigned to elbows?  Or the same color assigned to the elbows no matter what the pipe run is.
Mark Lancaster
HermJan.Otterman
can't you change the materials / colors of the parts in the Content Center?
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated Smiley Wink
Succes on your project, and have a nice day
Herm Jan
salariua
Mark is the expert, Herman has the answer and I am, as always late, to the party.
Make sure your T&P style has not force materials and they come as defined in CC
Adrian S.
blog.ads-sol.com
AIP2012-2020 i7 6700k AMD R9 370
Did you find this reply helpful ?
If so please use the Accepted Solutions or Like button - Thank you!
