Failed to insert the model in the IPN file
ehinson
ehinson
I have Inventor 2018. I try to create a IPN file and I get this message "Failed to insert the model. File does not include a valid model to be inserted in the IPN file.". Can somebody help me please? Thanks.
ehinson
Never mind. My IPN template file was an old version. After I used the 2018 template file it worked.
I'm running Inventor 2020 Pro and am having this problem. On everything. All I get is "Failed to insert the model. The <MODEL NAME> file does not include a valid model to be inserted in the IPN file."
It is not an old template file. It is fresh from the install.
johnsonshiue
Hi! Is the iam file last saved in 2021? Please share the files here.
Many thanks!
Software Test Engineer
No. It's all 2020. I haven't loaded 2021 yet.
johnsonshiue
Hi! Does it happen to any assembly you tried or one specific dataset? Please share the files here or send them to me in zip (johnson.shiue@autodesk.com).
Many thanks!
