All,
I am trying to insert a AutoCad file as a Overlay into Factory.
The problem I'm having is the text in the Autocad file scales up and becomes a thick font.....I can't see or use the geometry under the text (text becomes a thick wall above with the geometry below.
The text seems to have a life of it's own..otherwise the geometry is fine.
I know there are layer settings that can be turned on/off within factory.
I created a new file and stripped out the text from the AutoCad file to be able to use in Factory.....
Is there a solution to this issue?
Thank you in advance,
Bill
