Face Fillet , import to Revit
Hi, I'm a beginner, I want to import a tower from Revit to Inventor to do Fillet and then import again into Revit to make Face Fillet and then import again into Revit.
I did it by mistake, I do not know how I did, but I could no longer import it into Revit. Can I use the command only to parts?
EvanGu
In the first snapshot, you imported the geometry as 26 solid bodies, so can't find the edge to create fillet. Try to use Combine command to combine the soilds to get the boundary where you need to create fillet.
Evan Gu
Inventor/Fusion QA Engineer
Thanks, it was really useful to me.
